Power trim clicks
  • Power trim clicks
    I have a 50 hp 4 stroke(62y F50TLRY) a few months ago I had the trim motor replaced and it worked fine now for some reason it began clicking when I trim it up.It doesn't do it all the time it just clickes but it will go down all the time.Can you tell me the part and number that I can order Thanks
    Check all wire connections and grounds at trim relay make sure they are clean and tight.
    Could be a bad trim relay, number 23 in this diagram Yamaha Outboard Parts 2000 F50TLRY ELECTRICAL 2 Diagram
