I have posted problems before about the uneven performance of my 2002
Yamaha High Thrust 9.9 outboard. Usually, I am told to clean my carb.
My engine is generally working fine except under certain circumstances, it
lets me down. Passing under a bridge yesterday, it konked out and
fortunately I had enough way on to get through. It had run fine for
a half hour previous to this. It seems like after running the engine for any
length of time, it gets ornary when I lower the rpm to a slow speed.
Could the gas be going bad? I put in high octane in June and added some
stable to that. The engine is not run that often, maybe once a week for
an hour, since it is used as an auxilary power source for a sailboat. This
problem seems to come and go, but more prevalently under the conditions
I mentioned.
I also am experiencing a throttle las when going from idle to increased
power. I have to turn the throttle handle almost 1/3 it's full range before
the engine takes off. Once running, it has plenty of power and runs
smoothly.
So basically I have two problems, which may or may not be related.
Any ideas on the causes and suggestions for a cure?
I mentioned.
smoothly.
