I started the engine on muffs, and idled fine. Took her out for the first time (just got boat). put on water and couldn't get it to idle, changed fuel, plugs and cleaned main jets on carb, and cleaned 5 idle jets I wasn't able to remove the bottom one on the left side of motor, out of the 5 i cleaned 3 were pluged with devry. would one carb idle jet cause it to not idle and run rough? Should i removed all carbs and clean install a kit ? I also played around with the air mixture screw, got it to idle but doesn't run like it should. seems slow off the throtle, then it picks up.
