Hi everybody,
I recently brought a boat which came with a 55hp yamaha outboard 2 stroke (i think).
The plate on my motor says
The plate on my yamaha engine says as follows
> Yamaha 55AE
> 663 L 30043
I need a the 3 gaskets for the "oil level", "oil drain" and "wash" plugs as mine have all gone due to the previous owner leaving the boat in a harbour for a year without starting it up or cleaning it down !!
What i also need, And i will do my best to describe it to you.
From the main engine powerhead is a rod which connects the powerhead to the gear box/leg. The rod turns a quarter turn clockwise/anticlockwise depending on which gear you are selecting. The one which is on there now has rusted out before and someone has welding it back together but i do not like the look of it and would prefer a new one. Basically it is the rod which selects the gear for the engine and fits behind/in the mid-shaft.
I have updated the web page but it has no pictures of the gear selection rod at the moment and i would hope to get some pictures on there soon.
http://www.dvddealsuk.co.uk/boat
Thats the address if any body need to see what the engine looks like.
I believe the engine is a 55hp hence the 55AE on the plate. And when i took it to my local marine shop he said it was an 84/85 (84 or 85) model, but he wasn't positive about that.
I also need to know anything about whether it has an alternator to and what wires do what in the 7-wire wiring harness. The ignition key was lost by the previous owner and its now posible to start it with a 1 penny coin !!
Many thanks in advnace for any info
John
> Yamaha 55AE
> 663 L 30043
John
