I have an 87 50 hp yamaha that has been nothing but trouble.
After blowing a #1 piston, and having the head re-built, I have the following symptom:
When the motor is under torque (ONLY- it will run indefinitely, even at high rpm, when not in gear and in the water) the motor powers down and stalls after a few minutes at anything higher than about 2000 rpm. Higher rpms=faster power down. Worse in rough water.
I have had it tank tested by a reliable dealer, who said it apears that when the motor is under torque at high rpm, the flywheel drops a bit and bumps the coil, causing the power down.
He suggested MAYBE the main bearing, but no guarantees. I've talked to a couple engineers and small motor mechanics, who said, yeah, could be.
I want to minimize my expense, and I'm angry at this motor. I'm going to try to tear it down myself, and replace the main bearing.
Does anyone have similar experience? Any wise words of advice?
