I came home to see my motor in the down position and battery drained. I disconnected the motor and recharged the battery and as soon as I connected the motor again the trim motor is running in the down postion and will not come up when I press the up trim button. When I do press the up button it stops the trim motor and restarts again when i let go. Any suggestions?
power trim in continuous down position
Originally posted by jb123 View Postdisconnect each trim switch to see if one is bad.
disconnect blu and grn @ relay , apply 12v and ground to each ensuring motor is working right then sounds like your relay is stuck closed or you have corroded/pinched wires leading to switches.
Originally posted by jb123 View Postdisconnect blu and grn @ relay , apply 12v and ground to each ensuring motor is working right then sounds like your relay is stuck closed or you have corroded/pinched wires leading to switches.
Number 10 and 11 in this diagram are the trim relays Yamaha Outboard Parts 1993 115TLRR ELECTRIC PARTS 2 Diagram
ÂÂÂÂÂÂ
