1998-225 OX66 - rpm's @ wot
  • 1998-225 OX66 - rpm's @ wot
    I have a newly rebilt powerhead that I have not been able to get any more than 4200 rpm's at wot. The pre-rebuild would top @ 5300 rpm's @ wot.
    The motor runs fine at all other rpms.
    I have changed all fuel filters, seperators ,spark plugs and primer bulb
    What do I try next?
    did you clean/change vst filter?
    service/test 02 sensor?
      Ox 66
      Thanks, I'll try both.
        ox66-fuel mgmt
        Also, my fuel management guage for this motor(starboard) is running 50% to 100% higher than the port engine.
        Do you suppose the O2 sensor is responsible?
        I have not refueled the tank yet to see if this motor is actually burning this much more fuel or if the guage/sensor is faulty.
        Any thoughts are appreciated?
