need some help from anyone with prior experience with this motor, or similiar situation.
Last several years worked great. This year, problems suddenly occurred with shifting motor into proper gear. i believe linkage in gear shift assembly could be problem. For instance, when shift into nuetral, went into reverse. When shift into forward, grinding sound as if trying to engage, but not engaging. An inspection of the cables looks OK. The inspections of the gear shift assembly on the surface might be the problem with corrosion or a slippage of some sort. I since orded some respective parts to change.
Any other ideas as to what and where the problem may be would be greatly appreciated. Thanks
