I have a 1986 40hp ETLK with power trim and tried to bleed the system since it needs a little help getting started moving lately. The S.S hex head "purge" screw won't budge. Any ideas? Also, what is the correct size allen/hex?
To bleed air out of system, loosen the manual release screw on side of bracket. Lift motor to full tilt by hand, fill with fluid and then let motor trim down under it's own wieght. Repeat about three times keeping fluid topped off when in the up position. Tighten manual release screw.
