Oil Injection Pump
  • Oil Injection Pump
    I 'm replacing the oil injection pump in a 1989 V6 200 Yamaha. The new pump does not look the same,it was order with the model #. Anybody knows if is normal for the manufacture to redesign parts or I got the wrong part.
    Even the lever for the rod is different
    [FONT="Arial"][/FONT][I][/I]89 Presuit[FONT="Arial Black"][/FONT]
    If you recieved part number 6G5-W1320-00-00 then you have the right part, it is a newer style pump and comes with all parts needed to install.
      Thank You for the information. I also bought the original service manual from Yamaha, that may help me doing all the adjustments necessary for the pump, thank you again for reply.
