Need a lower unit for a 1990 yamaha 115
  • Need a lower unit for a 1990 yamaha 115
    Hello I am looking for a lower unit for a 1990
    yamaha 20 inch shaft. My unit works fine but has a crack near prop. I would also be interested in a lower unit case.
    I had this problem last year. I had the casing repaired, cost me £250 UKsterling. Engine done 50 hours since without a problem.
    have a look at www.castlemarine.co.uk to see how it is done.
    I was quoted £700 (UK) for new casing. Used gearcasing/boxes very rare because it is about the only problem these engines suffer from. if you do find one it is usually already cracked or will crack soon.
    Good luck
    Gary.
      Thank you Gary,I appreciate the advice.
      Tom
