Is there a neutral safety switch on the engine
  • Is there a neutral safety switch on the engine
    My question is is there a neutral safety switch on the engine? And if so where is it located..The engines are 1998 Yamaha saltwater series L200TXRX with 700 HRS
    dont think so, all up front.
      Thanks JB123
        neutral safety switch is inside the remote control....
          Thanks robert
            There is a NEUTRAL SWITCH ASSY on the motor.
              There is a shift switch on engine but the neutral switch is in control box.
                Replacing the Neutral switch
                Is it very hard to replace the Saftey Neutral Switch.
                  easy, just need to open 704, follow the 2 browns to the switch, you can jump it out to test
