I have 1989 200 v6 yamaha oil is going into one cylinder when the engine is off . all the oil drains. Anybody here knows whats going on.
Thank you for your helph
on an engine that old, it could be a number of things, my suggestion is unhook the oil injection and pre mix at 50:1 i really cant see potentially spending a couple hundred buck so a 20yr old engine. just my $.02
Boats.net can answer your question better than me but for what its worth. I have twin 1986 115,s oil injected motors. I had to replace one oil pump about five years ago due to problem you described, however other engine still has original oil pump on it.
