Details:
Motor is installed on a 420 Zodiac and propeller is exact same dia. and
pitch as Yamaha performance bulletin. 101/4X14. I have also tested with a
101/2X12. No difference. Symptons are lack of power on plane out and engine
rpm will not exceed 4200 under load. It will rev to 5800-6000 with no load.
I have had the engine to a local franchised dealer, not the selling dealer,
and all items checked out as new, leak down, compression and no error codes
voltages from sensor to fuel pump where at spec, plugs looked good. Dealer only had test tank.
So where might the problem lie? Engine runs smooth but weak.
