I have this gauge, 6YR-W0035-E2-00
I have looked in the owners manual and the service manual, and the operation manual;
When I turn the key switch what am I supposed to see or hear?
I believe my outboard is getting hot but no alarm or indicator on the round digital tach guage.
When I do turn the swith to the on position, not startong the motor,What I do see is the LCD bar above the temp Icon stays lit for a second or two, as do the oil indicators, however the oil indicators blink a few times, while the temp just disappears, i do not hear anything, should I. What should I be seing on the guages? I have tried to test the buzzer by hooking a 12v batt to it no sound or static whatsoever, it looks a bit corroded.??
I am aware of the tests for the Temp switch and the thermo sensor tests, testing them individually by them selves, however so that I know the system is working properly and that the signal get to the tach;.....
Is there a way to test the warning buzzer, Is there a way to bypass jumper The Black /Yellow on the Thermo sensor wires to test, how about the black Pink on the temp sensor switches as to get something to light or blink on the Tach?
I may have the incorrect operators manual for the gauges, may I have the one for the round, multifunction speed and tach, please?
