I am working on an engine that has not run in 3 years, it's a z150txrz. I've made progress but still have a way to go. I wanted to share something I discovered taking the high pressure pump apart. I had a good flow of fuel out of the VST and inline filter above but just a trickle to the fuel rails.
There appears to be an internal screen on the intake side of the mechanical pump. It's only accessable when you remove the pump cover. Mine appears to be gummed up and not passing any fuel. Anyone run into this? See atached photo, the screen is in the left side port which is the intake side.
I can't find the screen in any parts list so the options appear to be :
1. Remove it and leave it out
2. Attempt to remove clean and replace
I've read a number of posts where the mechanical pump has been repaced costing over $1,000. Might be worth a look....
