I have a 2000 Yamaha V-Max OX66 150 hp motor. It had been sitting for nearly 2 years so the gas in the tank was at least 2 years old but did have Seafoam in the tank. Went to start it a few days ago and it would not fire. Tried putting gas directly into the cylinders and it started but ran only until it burned that fuel. Here is what I have done so far with little no no success.
1) new plugs (early on)
2) Checked for bad fuses, found none
3) Found that the fuel pump was not running when the key was turned on - Took apart the VST, removed the pump and connected the leads to 12 volts. No luck so after reading here i connected oit to 24 Volts and it started to work. It then worked on 12 volts. Reassembled the VST and again no fuel.
4) checked for leaks in the hoses - none foud
5) drained the entire fuel system, tank and put in fresh gas.
6) used carb cleaner in the the throttle bodies and fuel rail - no luck
I can see fuel going into the throtle bodies when trying to start it. I dont have a gauge but there doesn;t seem to be any pressure on the shrader valve. I checked it when turing the engine over. Some gas does come out but it by no means squirts out.
I don't know if this is a fuel pump problem, injector problem, etc. I would appreciate any assistance.
Jason
Jason
