harness connection
  • harness connection
    HI I am after the wiring diagram for my harness on my yamaha 50 hp power trim and tilt elec start 2005 model the sky blue wire on the key switch side has pulled out from the connector and I need to know which color it connects to as there is no sky blue on the engine side as I was just going to wire it accross the connector?any help would be great
    thanks ,
    The light blue wire is trim up wire, connects trim switch on control box and connecto trim relay on engine.
      ok this is my problem in the photo the blue has pulled from the connection can I just hard wire it and run a wire to the other side of the connection if so what color would this blue wire connect to as I cannot see into the harness connection to get a match also there is no matching color wire?here is a photo of the blue wire
      thanks
        Can't tell from photo what wire harness that is.
          its the 10 pin connecting harness that runs from key switch, could this be the choke wire?
          thanks
            Yes that would be choke wire.
