I have a 86 Yamaha 40hp ELJ. The only work I have ever had to do on the lwr. unit is replace an impeller. This year while replacing oil I noticed water in it. I took off the prop and removed the fishing line I found there. (That had happened before and fixed the problem) Ran the boat on the lake and was great for 40 mins. then heard a gargling sound. Checked lwr. unit and found alot of water in it. Also, when I spin the prop by hand there is a clicking sound that I don't remember being there. By reading previous posts I think I should replace the oil seals (93332-000V4-00) and maybe the bearings too?
Is this a very hard job? Do I have to pull the lwr. unit off first? (Like I did when I replaced the impeller) Any advice I could get before I do this would be greatly appreciated.
