Changing T-Stats
  • Changing T-Stats
    Hi guys,
    I have a 2002 150 HPDI Z150TXRA and I want to change the thermostats. While checking out the job I see a black plastic cover that protects some of the wires including spark plug and the injectors, that needs to be removed to access the botttom bolt and remove the housing.
    Therein lies the problem. I was able to snap the cover off ( for want of a better description there are two plastic fingers that hold it in place on each side )but now I can't seem to get it to snap back on. Nothing broke off or streched out of shape and I'm wondering if anyone out there has done this job if there is a tip or trick to replacing this cover that I'm missing.
    I'm also changing the water pump. Seems pretty straight forward but any advice would be appreciated.
    Thanks in advance for the help and information...........................Joe
