703 Side Mount - compatibility with F60?
  • 703 Side Mount - compatibility with F60?
    I am looking at a used 703 remote control box - apparently it was previously used with an older 70 2-stroke. It has a 10-pin electrical connector at the motor end. Will this be compatible with the F60 I'm going to be getting next fall? Thanks.
    Tim
    if it says push to open on the bottom, then yes it is, if it says pull to open, no it is not
