I'm stumped here. I can't get any water out of the pee tube.
The engine (115 2 stroke) has been in storage for 2 years and was peeing before storage.
This is what i've done so far to try to fix it.
Changed the water pump. Cleaned the pee tube and tubing from power head to the outlet (small clog in the outlet).
I removed and checked the thermostats (some salt deposits but they worked in hot water on the stove)
I'm not sure what else is left. I've tried on the ear muffs and in a test tank.
I have only run the engine for 2-3 minutes so it doesn't overheat (I don't trust my alarms right now).
Is there some other way to find out if the water is pumping through the system?
Any ideas?
JP
Any ideas?
JP
