You would need
703-48207-17-10 703 side mount control box
(2) MAR-CABLE-xx-SC(replace xx with length need) Throttle/Shift cables
If your engine has a 7 pin main harness connected to tiller handle then also need 703-8258A-00-00 7 to 10 pin adapter
If you want remote steering then also need
65W-48511-10-00 Steering hook
65W-61350-00-00 Steering arm
