I've been recommissioning a 1995, 115HP Yamaha after being in storage for 2 years and not serviced by the previous owner for at least 2-3 years before that.
It runs ok so far and the last problem area is the lower unit which hasn't seen service in 4-5 years.
Today I tried changing the water pump but have some issues. I got the impeller off after 2 hours of heat, prying and cutting but am stuck with the Woodruff key. It's severely corroded and chipped. So far I can't remove it. I've tried heat, WD40, and chiseling/punching but so far no luck. I'm worried it will chip to flush with the shaft. Any tips or just keep chipping away? I have to remove it to install the new bottom plate (the old one is destroyed)
Next when removing the impeller I found many pieces of a small spring. I think the goes in the oil seal. What's the part number and how do I replace it? I can't find a reference in the Seloc manual. Are there other parts I should replace at the same time (besides the water pump kit)?
Finally, I drained the gear case oil. Just under a quart came out and it's nearly pitch black. No metal in the fluid or on the drain plug magnet. Doesn't seem to be any water mixed in but I have it settling to see. Is this a sign of anything or just past due service?
Any advice based on all this? I want to get this fixed up and in the water ASAP.
JP
JP
