I purchased a new speedometer 6Y5-83570-S5-00 to replace my malfunctioning unit (the LCD is hosed - moisture inside). The original 1998 set of gauges are connected to 1998 twin 200 saltwater series.
The new gauge does not have the wiring connection that will allow me to connect to the FM Gauge (the connection looks like S-video). I am aware of the 3 pin connection below the dip switches. The equivalent wire on the old gauge is soldered in place to a similar 3 pin connection point.
1. Is there a wiring harness I need to purchase to make this connection? Part Number?
2. Are there any differences between the old gauge and the new gauge that I need to be aware of or make additional modifications for? There appears to be one less ground wire on the new gauge. My assumption is that the "absent" ground connection was made internal to the gauge.
Thanks in advance
Thanks in advance
