Please can any-one advise on:
The engine is off, gearshift control in neutral - prop turns freely.
Put gearshift in reverse - manually turn prop and it tries to turn the engine.
Gear shift in forward - what should happen when you turn the prop? Should it also try to turn the engine or not? (Mine doesn't it just makes a clicking sound as you try to turn it, but I thougt it should also try to turn the engine).
I've run it up with muffs and everything seems fine. I can't actually get it to the water for a couple of weeks yet - so don't know how it performs under pressure of the water. I just want to know whether it is Ok or not. Its really beggining to bug me.
Wondered if any one out there could advise.
Thanks,
Alan.
Thanks,
Alan.
