1984 90 ETLN Flywheel Puller?
  • 1984 90 ETLN Flywheel Puller?
    Do I need a special flywheel puller for this or can I use a different puller than the Yamaha special puller and holder.
    And if I have to use the Yamaha one where can I get it?
    Thanks Jeff.
    Just get a automotive type harmonic balance puller. Snap-On tools has them that includes metric puller bolts.
      Thanks, that is what I was hoping for. I have one already.
      Jeff.
        when you use the puller dont pull it with just puller pressure put some pressure on the flywheel then rap on it with a hammer and it will pop off if you try to just use puller pressure when it comes off it will fly across the room or you will break off the bolts in the flywheel
