HI,
My engine was running poorly at what I call "*****ing speed". Liek when the engine is putting through a no wake zone. I will add that it ran great @ WOT and @ idle.
SO...I decided to clean the carbs. They did have some varnish and are now clean, floats adjusted (they were fine) new needles and gaskets.
Question. when I backed out the idle adjustment screws they were all @ 2 1/8 turns. The manual I believe calls for a max of 7/8. Seeing how the idel was fine should I put them back where they were? OR where the manual calls for? Or something else?
Also I did test run the boat (with screws @ 7.8) and it had the same coughing problem at *****ing speed. I have read the manual on the 3 basic carb circuts and focussed on the BYLASS circut. I took the carbs apart again and cleaned again. Looks fine.
Should I be looking anywhere else?
