Hi all
(I have also posted this on iboats.com >>> Compression test—OOPS! - iboats Boating Forums)
I was doing a comp test on my Yamaha 50HP 4 stroke-
Yamaha F50T
1994 or 1995
And---- the gauge’s valve stem got sucked into number one cylinder and then started to blow back out in little pieces!
I bought a new comp gauge and yup-- Cyl one reads way low—
Cyl1: 25 PSI
Cyl2: 175
Cyl3: 180
Cyl4: 175
I have never opened up an engine before. I have the pdf version of Lit18616FT50 which I purchased on the net last week. I have lots of time.
I have since removed the head-- looks OK.
Cyl 1 is full of ground up valve stem.
I am trying o get piston1 out.
Please--- do I have to remove the entire powerhead to get the crankcase cover off, so as to get that piston out.
Thanks a lot-- Rick in Anchorage.
Yamaha F50T
1994 or 1995
Cyl1: 25 PSI
Cyl2: 175
Cyl3: 180
Cyl4: 175
