Compression test—OOPS!
  • Compression test—OOPS!
    Hi all
    (I have also posted this on iboats.com >>> Compression test—OOPS! - iboats Boating Forums)
    I was doing a comp test on my Yamaha 50HP 4 stroke-
    Yamaha F50T
    1994 or 1995
    And---- the gauge’s valve stem got sucked into number one cylinder and then started to blow back out in little pieces!
    I bought a new comp gauge and yup-- Cyl one reads way low—
    Cyl1: 25 PSI
    Cyl2: 175
    Cyl3: 180
    Cyl4: 175
    I have never opened up an engine before. I have the pdf version of Lit18616FT50 which I purchased on the net last week. I have lots of time.
    I have since removed the head-- looks OK.
    Cyl 1 is full of ground up valve stem.
    I am trying o get piston1 out.
    Please--- do I have to remove the entire powerhead to get the crankcase cover off, so as to get that piston out.
    Thanks a lot-- Rick in Anchorage.
    Yes to remove the piston the powerhead would have to be removed.
      Thank you.
      Everything points to the cyl being OK. I am reassembling now.
      Rick
