I just did a major overhaul on my boat, stringers and things, now that my boat is hooked up, I am noticing the motor isn't running the same as it was before.
When I tore it apart, we broke the bracket on the shifter because the bolts were frozen in it. The motor never came off of the boat and all the cables to the motor stayed intact. My buddy who works on outboard motors, had a like new Suzuki shifter, it had all the same markings as the Yamaha shifter not too mention it looked exactly alike.
I used to turn the key and get a beep beep sound, I don't get that anymore?
Also, now if I ease into the throttle, the motor boggs all the way to 2900 RPM's, at 3000 it hauls ass all the way up to 5500.
My mechanic told me that the motor is supposed to run on 4 cylinders up to 1800 rpms but it seems mine is now running on 4 cylinders all the way up until 3000 rpm's.
We changed the throttle control sensor to see if when the flaps were opening they weren't activating the throttle control sensor but this did nothing.
Is there any adjustment to make the motor kick in all 6 cylinders earlier than 3000 rpm's.
