can't find the answer to this anywhere -- the 150 will not start, but after cranking and the key is returned to the "on" position, i get a beep - not the same beep as when you first turn on the ignition but an intermittent beep such as "BEE BULL-BEE BULL-BEE BULL" this will continue until ignition is turned off. is this trying to tell me something? talked to a few dealers - they never heard of it, said it was low oil or high temp , but these alarms are a steady beeeeeep. any ideas???
2 stroke 150 - alarm
You will get an alarm if the landyard cord(emergency stop) is unplugged which will prevent it from starting. If cord is plugged in then check stop switch.
Originally posted by boats.net View PostYou will get an alarm if the landyard cord(emergency stop) is unplugged which will prevent it from starting. If cord is plugged in then check stop switch.
The landyard will stop ignition from firing but engine starter will still crank engine over.
Twin engines use a different key switch panel, it has a stall warning. If engine stalls or shuts of it will activate an intermitten beep.
ÂÂÂÂÂ
