- just put new impeller kit, slightly confused bou which goes on top
(discrepancy between shop manual & parts diagram )
paper gasket or metal plate ?
- the motor is missing the "shim anode " which is located on the underneath of cavitation plate, will this mess w/ impeller action ?
I have both air//water thru water pie up and both come thru "peehole "
- have removed questionable thermostat so that should not be hindering flow
AND YES- new parts have been ordered for all mentioned
SPENT HALF MY WEEKEND ON THIS AND STILL NO RESULTS !!!!
uuuuuuurggghhhhh.
-thanks fellow Yammies
jib.
uuuuuuurggghhhhh.
jib.
