1993 C115 yamaha outboard motor model tlrr
I am having a problem with motor starting but I can take the cover off and let it sit for a hour or so and it will fire once or twice like its going to start then nothing then go back out and fires up and runs great I am not getting spark the times it does start and just turns over.I have changed fuel pump hose pulled carbs cleaned.I am getting fuel no fire.I did a ohm test dont know what the spec are suppose to be in ohms chart would help if anybody has one check kill switch
This are ohms test.
W/R TO W/Y=0.359k to 0.362 kinda moves around and sit at 0.359k
W/B TO W/G= 0.362 and it stays their
ALL THIS WAS WITH WIRES OFF THE POWER PACK LET ME KNOW IF I AM DOING THIS RIGHT.
This are ohms test.
