i have a yamaha 15hp pull start. What do i need to do to get it to charge a battery there are two wires coming out from under the flyweel? What are thay for
Grady
You can buy a voltage regulator that connects to the two Green Wires and connect and charge a battery. We would need the model number to get right part number
