Running two fuel lines from the main tank/ filter
  • Running two fuel lines from the main tank/ filter
    My main motor is the F 150 and I have an F 9.9 kicker. The fuel line from the tank runs to my Racor water separating filter that supplies the F 150. I would like to supply fuel to the kicker from the same (main) tank. Some say that it is fine to just run another fuel line with a primer bulb from the second outlet of the Racor filter to the kicker. It has also been said that when supplying a kicker in this manner, one should install an on/ off valve in each line to separate the fuel flow from each motor. Is one method preferred over the other or does it matter? Thanks in advance...
    Ron
    It would need a selector valve between engines.
