On my 2018 F90 yamaha their ended up being a main loose ground wire to the motor by the tilt relay. Than on the relay itself I found another loose wire nut on the relay itself. Problems are resolved. The relay for tilt was fine.
no power to tilt and trim and motor won't start
Originally posted by bryfly40 View PostOn my 2018 F90 yamaha their ended up being a main loose ground wire to the motor by the tilt relay. Than on the relay itself I found another loose wire nut on the relay itself. Problems are resolved. The relay for tilt was fine.
History is useful but it requires good fault finding principles, as it is all to easy to assume your fault is the same as another person’s and go offf on a long unnecessary time consuming and costly path.
- 2 likes
Originally posted by bryfly40 View PostI'm going to replace the tilt trim relay. Will post my results on my F90 yamaha 2018. Yes still under warranty but their a month out. Record boat sales and service. Mn lolLast edited by bryfly40; 07-13-2020, 01:47 PM.
