2006 Yamaha 15 HP, 4-Stroke (EL). This will be my first attempt at replacing the water pump. I have purchased the factory Yamaha Service Manual, as well as the complete water pump replacement kit.
The diagrams appear pretty straight forward with regards to the pump itself. However, there is little written with regards to removing the lower unit and replacing it properly.
I am somewhat mechanically inclined, but can find no references in the manual, with regards to returning to the original shift linkage adjustment, once I disconnect it. Also, no where in the manual is the procedure(s) outlined with regards to either removing and/or replacing the lower unit properly. I would sincerely appreciate any/all help/suggestions you may have to offer me. Thank you all!
