1989 130 hp outboard no reverse
  • 1989 130 hp outboard no reverse
    the reverse will not engage on our 1989 130 hp when put into reverse. Even when the shift cable is disconnected and manually put into the full reverse position, it will not engage, just grinds.
    has your shift shaft been changed from the old steel one??? look at it above the lower unit and see if its rusted out.
