how do you change the water pump on the jet drive
2002 70 hp with jet drive
Same as prop model, remove the jet drive and water pump sits on top of drive.
Remove the intake housing, remove jet pump impeller then remove the four bolts to disconnect pump housing from adapter plate. The water pump sits on top of housing.
jet drive
i have a question for some old mercury guys
i have 89 60 hp 3 cly long shaft with prop i want to convert to a jet the drive for my yr IT is a p drive which was discontinued it is a large drive i waS TOLD BY SOMEONE THAT YOU CAN USE & E DRIVE WHICH IS A MEDIUM DRIVE & GET GOOD PREFORMANCE FROM IT CAN ANY ONE HELP
LEO
