yamaha gauge malfunction
  • yamaha gauge malfunction
    I have a 2003 yamaha 115 v4. I completed some work that required me disconnecting the battery. Now my Tilt meter shows that the tilt is at maximum up, and flashes indicating so. The oil meter also shows the reservoir flashing half full when both have checked full. Any reset suggestions, being this worked fine before.
    No reset, sounds like wire harness is unplugged. Check the square off white colored connector at gauge and at engine to see if unplugged.
      Ok, Thanks
