I have lost all top end on my pro v 150. Was running fine, then all the sudded just came off plane. I cannot get it to get on plane. I ran a compression test w/ all plugs out w/ the following results: 44,45,50,45,45,50. Everything I've read on here says they should be w/in 10 % of each other, so that part looks ok, but I also see that most engines are around 120-125 psi. I removed the head and the gaskets showed no sign of blow-by. The cylinder walls look smooth...no scarring or pitting. Anybody know why readings would be so low? Is this a low compression engine? ( engine code is
ro v 150J 6J9 L 302425) Thanks, Mark.
![Stick Out Tongue](https://www.yamahaoutboardparts.com/core/images/smilies/tongue.png)
