Just had some work done on my new replacement motor after my 12 month old motor was stolen,
Susiquently I found the Yamaha Dealer fitted the parts incorrectly when fitting a new remote, how i know is I had fitting issues in Feb 2008 so i have corrected this myself.
This then made me look at the rectifier that was also fitted, after noticing the charge coil wires being streched depending on the throttle position I feel the unit and the wiring loom is not in the correct spot.
Can someone tell me where it should be mounted and where the wires should be loomed to limit fatigue on the moving charge coil wires ?
A picture would be nice
Regards Stephen
Regards Stephen
