Hello All. I have a 2009 F60 with command link system. Its all working great except the trim, its always reading zero on the gauge display. I contacted my Yamaha dealer and they told me that there are two pink wires on the engine that need to be connected but I havent had any success finding the wires. Any suggestion of info would be appreciated.
Command Link Trim Problem
I dont know if my motor is setup the same as yours but I had a similar problem on my twin 99 150's. The problem was the trim sender switch was broken on both motors. They are made of plastic and break often but since then yamaha upgraded to a stainless switch.. Check this link it is part #64E-43139-00-00 #1 on the diagram
Yamaha Outboard Parts 1999 SX150TXRX BRACKET 2 Diagram
hope this helps
Roger
