hello all,
i have recently bought a used power head to replace an unserviceable 90etlh. i have no model number for the engine it came from and am having trouble ordering a piston. pistons one and three are in great shape and the block is perfect, so i don't want to mess around with boring it out. i was told the engine overheated and instead of letting it cool after the auto shutoff, the genius just pulled the temp sensor. as a result, piston two melted a little and needs replaced. unfortunately none of the pistons match the specs in my FSM . the two good pistons measure 3.2403" (~82.3 mm) @ 0.39" above skirt bottom, and are marked 6H103. what replacement piston should i buy?
thanks
Jason
thanks
Jason
