I am installing a multi-function tachometer on a 2006 90TLR.
The kit is 6YR-W0035-15.
This includes
6Y5-83500-T2 - Tach
6Y5-83553-00 - Tach to remote harness
64D-82553-70 - Oil/Trim harness to engine
The engine has one square plug with green, green/red, pink, and gray wires. The harness I have has 2 square plugs. One side has 2 pins green, green/red. The other side has 4 pins pink, black, gray, and orange.
Right now, with the remote box and the green and green/red wire on the engine harness connected, I have RPM registering, oil registering full, trim all the way at 5 with the top bar flashing. It appears that everything reads correctly except trim, which I believe are sent from a pink and gray wire on my engine.
From searching the internet, I believe I need another harness from the engine to the gauge. Do you know the part number, or is there a way to get this one to work?
Thanks for all the information on the site, it is very helpful.
This includes
6Y5-83500-T2 - Tach
