Anyone have wiring diagram for '04 & '05 F225 4 strokes tach leads at motors. Colors are different from harness just want to make sure I get it right.
email dcabot@comcast.net
If you are using the digital gauges with trim/oil harness just connect the off white colored square connectors on motor to the off white colored square connectors on trim/oil harness(wire colors may not be same).
Then you would need a 68F-82553-90-00 Yamaha Trim/Oil harness for the 2004 and a 6Y5-83653-10-00 for the 2005, then the Yamaha gauges will plug up to harness.
