After setting up for a couple of weeks the engine will turn over but will not start. If the 30 amp fuse is pulled and the same fuse put back in, the egine will will start. If the engine is run ever few days there is not a problem.
The above went on for several months, then the fuse went out while running at speed the last time out.
This problem started after having the rectfier and regulator replaced.
