F225 out drive problems
  • F225 out drive problems
    Having trouble shifting into forward/reverse.
    Very stiff, still works, but getting worse.
    Checked the cables, no problem, so it must be in my lower unit.
    Has any one repaired (successfully!) their own?
    What special tools are required.
    Any tips or tricks?
    I'm very handy, having rebuilt my 115 and 225 4-strokes over the years, and have the factory manual.
    Thanks,
    Kevin
    Hi Kevin, before you take the lower unit apart, have you disconnected the cables at the motor and checked if the problem went away? Sometimes a visual only inspection of the cables is not enough.
    Dennis
      Dennis,
      Yep, first thing.
      Cables run free when not attached.
        did you run motor with cable unattached and engage gears by hand ?
          No haven't tried that, what would it tell me?
          and who let the idiot in?
            if unit engages via hand it is good, just because cables move they may be out of adjust
              kevin, nobody here is a idiot! We are all here to help each other, and to help out and offer suggestions, which usually come from our personal experiance. If this is not suitable to you, please keep your remarks to yourself.
              Dennis
                the spammers and ****
                whats bad and you did not see it spammers get on the thread
                I know its hard for the mideators to catch it all
                but the ****s a little bit my 8 year old looks stuff up for me whem iam out side
                but after the other day thats not going happen anymore
                just my take on that
                  amazing it can automaticly delete the p word and not grafic pictures
