Battery Wiring Yamaha TLR 60
  • Battery Wiring Yamaha TLR 60
    I'm adding battery cable ends on the wiring coming from the motor that has been cut. The 2 cables coming from the motor are factory wiring.
    One cable is all black, the other cable is black with a white stripe.
    Which one should be connected to the positive side of the battery ?
    Probably one with white stripe, check it for continuity with an ohm meter to make sure.
